09 High Availability Command Reference
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-EI[SI] Switch Series Command References-Release 2210-6W10009 High Availability Command Reference
Download Book
Preface
The H3C S5500-EI & S5500-SI documentation set includes 10 command references, which describe the commands and command syntax options available for the H3C S5500-EI & S5500-SI Switch Series Release 2210.
The High Availability Command Reference describes fault detection and fast failover configuration commands. With these commands, you can detect and diagnose your network, and rapidly recover your network when failures occur.
This preface includes:
·           Audience
·           New and changed commands
·           Conventions
·           About the S5500-EI & S5500-SI documentation set
·           Obtaining documentation
·           Technical support
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the S5500-EI & S5500-SI Switch Series
This section describes by book the new and changed commands in software release 2210 over release 2208 for the S5500-EI and S5500-SI switches.
Feature module
New commands
Changed commands
Ethernet OAM
·       oam loopback interface
·       undo oam mode
N/A
CFD
N/A
·       Default command levels of the commands cfd linktrace and cfd loopback changed to visit, and the commands became available in any view.
·       Command levels of these commands changed to monitor: display cfd ais, display cfd dm one-way history, display cfd linktrace-reply, display cfd linktrace-reply auto-detection, display cfd ma, display cfd md, display cfd mep, display cfd remote-mep, display cfd service-instance, display cfd status, display cfd tst, reset cfd dm one-way history, and reset cfd tst.
DLDP
N/A
N/A
RRPP
N/A
·       S5500-EI only: Value range for the domain-id argument changed to 1 to 24 in the commands display rrpp statistics, display rrpp verbose, domain ring, reset rrpp statistics, and rrpp domain.
·       Value range for the instance-id-list argument changed to 0 to 128 on the S5500-EI and 0 to 32 on the S5500-SI.
Smart Link
port smart-link group track
Monitor Link
N/A
N/A
VRRP (only available on the S5500-EI)
N/A
·       Option forwarder-switchover member-ip ip-address was added to the vrrp vrid track command.
·       Option forwarder-switchover member-ip ipv6-address was added to the vrrp ipv6 vrid track command.
Stateful failover (only available on the S5500-EI)
N/A
N/A
BFD (only available on the S5500-EI)
N/A
Command level of these commands changed to monitor: display bfd debugging-switches, display bfd interface, display bfd session, and reset bfd session statistics.
Track
N/A
N/A
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
?WARNING
?CAUTION
?IMPORTANT
NOTE
?TIP
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5500-EI & S5500-SI documentation set includes:
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
Hardware specifications and installation
Compliance and safety manuals
CE DOCs
Provide regulatory information and the safety instructions that must be followed during installation.
Quick starts
Guides you through initial installation and setup procedures to help you quickly set up your device.
Installation guides
Provides a complete guide to switch installation and specifications.
PSR150-A [ PSR150-D ] Power Modules User Manual
Describe the specifications, installation, and replacement of hot swappable 150W power modules.
RPS Ordering Information for H3C Low-End Ethernet Switches
Helps you order RPSs for switches that can work with an RPS.
User manuals for RPSs
Describe the specifications, installation, and replacement of RPSs.
User manuals for interface cards
Describe the specifications, installation, and replacement of expansion interface cards.
H3C Low End Series Ethernet Switches Pluggable Modules Manual
Describes the specifications of pluggable transceiver modules.
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
H3C Series Ethernet Switches Login Password Recovery Manual
Helps you deal with switch login password loss.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
